Problems with 8mm pattern sphere
Hello everyone, Does anyone have an 8mm diameter calibration sphere? If so, could you tell me the diameter of its stem? I've acquired an 8mm sphere, and although the Master probe calibrates it correctly, I then get an error when calibrating any probe. I receive the following warning: "Probe calibration could not be performed with this reference sphere. Check the stem radius of the reference sphere. It has been detected that the stem radius of the reference sphere is more than 60 percent of the radius of the reference sphere."
Thanks Jens, But did you have to change the stem or did you just change it in the settings?
I only changed it in the setting, I had no collision with the stem after that
Unless you specifically are not using the RSH, make sure you setup your reference spheres as RSH, so that the correct shaft radius is pulled in. Otherwise, if you leave it on Other and just set the Sphere Radius, the default Shaft Radius is 6mm. If you tell it an RSH, and CZSphereD8 the Shaft Radius will default to 1.5mm
