[Da...] Posted yesterday at 09:24 AM Share Posted yesterday at 09:24 AM Hello everyone, Does anyone have an 8mm diameter calibration sphere? If so, could you tell me the diameter of its stem? I've acquired an 8mm sphere, and although the Master probe calibrates it correctly, I then get an error when calibrating any probe. I receive the following warning: "Probe calibration could not be performed with this reference sphere. Check the stem radius of the reference sphere. It has been detected that the stem radius of the reference sphere is more than 60 percent of the radius of the reference sphere." Link to comment Share on other sites More sharing options...
[Je...] Posted yesterday at 10:25 AM Share Posted yesterday at 10:25 AM Yes, I had to set it to 1,5mm to make it work Link to comment Share on other sites More sharing options...
[Da...] Posted yesterday at 10:54 AM Author Share Posted yesterday at 10:54 AM Please sign in to view this quote. Thanks Jens, But did you have to change the stem or did you just change it in the settings? Link to comment Share on other sites More sharing options...
[Je...] Posted 23 hours ago Share Posted 23 hours ago Please sign in to view this quote. I only changed it in the setting, I had no collision with the stem after that 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted 23 hours ago Share Posted 23 hours ago Unless you specifically are not using the RSH, make sure you setup your reference spheres as RSH, so that the correct shaft radius is pulled in. Otherwise, if you leave it on Other and just set the Sphere Radius, the default Shaft Radius is 6mm. If you tell it an RSH, and CZSphereD8 the Shaft Radius will default to 1.5mm 1 Link to comment Share on other sites More sharing options...
[Da...] Posted 3 hours ago Author Share Posted 3 hours ago Thank you so much, guys! I did it! Link to comment Share on other sites More sharing options...
