[Lu...] Posted March 9 Share Posted March 9 (edited) Please sign in to view this quote. Edited March 9 Link to comment Share on other sites More sharing options...
[Ri...] Posted March 9 Share Posted March 9 Evaluation - Limit evaluation - Nom. Vector Direction On - Edit - select the first/end point of each section. See if that helps. 1 Link to comment Share on other sites More sharing options...
[Lu...] Posted March 10 Author Share Posted March 10 (edited) Please sign in to view this quote. I’m afraid I don’t know how to do it. Each segment has 500 points, so there are no additional points to delete or hide. 1–500 is one segment, 501–1000 is the next segment, 1001–1500, and so on. Edited March 10 Link to comment Share on other sites More sharing options...
[Ma...] Posted March 10 Share Posted March 10 Just select with CTRL key first and last point from those segments - aka 1,500,501,1000,1001,... Also i would consider usage of Spline evaluation than Gauss ( it should be on 2nd tab - Rozšířené ) Zkrátka označíš první a poslední bod segmentu tak aby měl černou šipku - tím se eliminuje tento bod k vyhodnocení. Link to comment Share on other sites More sharing options...
[Cl...] Posted March 10 Share Posted March 10 Open a blank curve and recall the points from the initial curve(s) 1 Link to comment Share on other sites More sharing options...
[Lu...] Posted March 16 Author Share Posted March 16 I recreated the entire curve with all paths and then did the following: Curve → Evaluation → Standard → Direction of the nom.vector → deselect the points you don’t want to evaluate. And that’s it. Thank you for your help! 3 Link to comment Share on other sites More sharing options...
