getParameterNamed() only working for integers?
Hi, i have a .txt that im reading with readListFile()
This is what it contains:
With this code:
offtsetCoordinates = readListFile(offsetFile)
ballFinderOffsetX = (val(getParameterNamed(offtsetCoordinates,1))/1000)
ballFinderOffsetY = (val(getParameterNamed(offtsetCoordinates,2))/1000)
ballFinderOffsetZ = (val(getParameterNamed(offtsetCoordinates,3))/1000)
coordsys = getParameterNamed(offtsetCoordinates,4)
I get the two "0" values correctly because i guess they are integers and the rest is just "".
I could make the file comma seperated and then use
offSetStuff=offsetFile.asFilename.contentsOfEntireFile
xOffset = val(strElement(1,",",offSetStuff)))
yOffset = val(strElement(2,",",offSetStuff)))
zOffset = val(strElement(3,",",offSetStuff)))
coordSys = val(strElement(4,",",offSetStuff)))
But i dont want that tbh.
Is there a way to use getParamteterNamed() for that?
What exactly ist it that doesn't work with your first code? If I simulate it, I get 0, 0 and -0.1d
What exactly did you get and what did you expect instead?
I never had any problems reading mixed lists with getParameterNamed()
Edited
ballFinderOffsetX = (val(getParameterNamed("offtsetCoordinates",1))/1000)
ballFinderOffsetY = (val(getParameterNamed("offtsetCoordinates",2))/1000)
ballFinderOffsetZ = (val(getParameterNamed("offtsetCoordinates",3))/1000)
coordsys = getParameterNamed("offtsetCoordinates",4)
Posted (edited)
Hi Norbert,
here u see what im getting here (ignore the parenthesis in front of val(), it doesnt change the result)
And i swear, yesterday when testing the same code got me "" for
Edited
I used the format from your original post (no "" around offsetCoordinates) and still got -0.1d for the 3rd value (-100.0). I used display() for output.
Edited
I guess im going to install the latest sp and see if it still behaves like that
I restarted Calypso 20000 times during testing with no influence on the result. After restarting the PC to install the new sp its now working as intended
Okay, its not working again. It takes floats now, but the strings stay the same... String just become an empty string 😞
Make sure you file is encoded with UTF-8, other encodings can cause issues with readListFile() and the regular filestream.
If I recall correct 7.8 was the first version to use a more roboust filestream.
Edited
  • Like! 1
You gave me hope for a second, but unfortunately my files are encoded with UTF-8 😞
