[Ro...] Posted 20 hours ago Share Posted 20 hours ago Hi, i have a .txt that im reading with readListFile() This is what it contains: With this code: offtsetCoordinates = readListFile(offsetFile) ballFinderOffsetX = (val(getParameterNamed(offtsetCoordinates,1))/1000) ballFinderOffsetY = (val(getParameterNamed(offtsetCoordinates,2))/1000) ballFinderOffsetZ = (val(getParameterNamed(offtsetCoordinates,3))/1000) coordsys = getParameterNamed(offtsetCoordinates,4) I get the two "0" values correctly because i guess they are integers and the rest is just "". I could make the file comma seperated and then use offSetStuff=offsetFile.asFilename.contentsOfEntireFile xOffset = val(strElement(1,",",offSetStuff))) yOffset = val(strElement(2,",",offSetStuff))) zOffset = val(strElement(3,",",offSetStuff))) coordSys = val(strElement(4,",",offSetStuff))) But i dont want that tbh. Is there a way to use getParamteterNamed() for that? Link to comment Share on other sites More sharing options...
[No...] Posted 19 hours ago Share Posted 19 hours ago (edited) What exactly ist it that doesn't work with your first code? If I simulate it, I get 0, 0 and -0.1d What exactly did you get and what did you expect instead? I never had any problems reading mixed lists with getParameterNamed() Edited 19 hours ago Link to comment Share on other sites More sharing options...
[He...] Posted 15 hours ago Share Posted 15 hours ago offtsetCoordinates = readListFile(offsetFile) ballFinderOffsetX = (val(getParameterNamed("offtsetCoordinates",1))/1000) ballFinderOffsetY = (val(getParameterNamed("offtsetCoordinates",2))/1000) ballFinderOffsetZ = (val(getParameterNamed("offtsetCoordinates",3))/1000) coordsys = getParameterNamed("offtsetCoordinates",4) Link to comment Share on other sites More sharing options...
[Ro...] Posted 2 hours ago Author Share Posted 2 hours ago (edited) Hi Norbert, here u see what im getting here (ignore the parenthesis in front of val(), it doesnt change the result) And i swear, yesterday when testing the same code got me "" for coordsys = getParameterNamed("offtsetCoordinates",4) Edited 2 hours ago Link to comment Share on other sites More sharing options...
