[Ro...] Posted March 10 Share Posted March 10 Hi, i have a .txt that im reading with readListFile() This is what it contains: With this code: offtsetCoordinates = readListFile(offsetFile) ballFinderOffsetX = (val(getParameterNamed(offtsetCoordinates,1))/1000) ballFinderOffsetY = (val(getParameterNamed(offtsetCoordinates,2))/1000) ballFinderOffsetZ = (val(getParameterNamed(offtsetCoordinates,3))/1000) coordsys = getParameterNamed(offtsetCoordinates,4) I get the two "0" values correctly because i guess they are integers and the rest is just "". I could make the file comma seperated and then use offSetStuff=offsetFile.asFilename.contentsOfEntireFile xOffset = val(strElement(1,",",offSetStuff))) yOffset = val(strElement(2,",",offSetStuff))) zOffset = val(strElement(3,",",offSetStuff))) coordSys = val(strElement(4,",",offSetStuff))) But i dont want that tbh. Is there a way to use getParamteterNamed() for that? Link to comment Share on other sites More sharing options...
[No...] Posted March 10 Share Posted March 10 (edited) What exactly ist it that doesn't work with your first code? If I simulate it, I get 0, 0 and -0.1d What exactly did you get and what did you expect instead? I never had any problems reading mixed lists with getParameterNamed() Edited March 10 Link to comment Share on other sites More sharing options...
[He...] Posted March 10 Share Posted March 10 offtsetCoordinates = readListFile(offsetFile) ballFinderOffsetX = (val(getParameterNamed("offtsetCoordinates",1))/1000) ballFinderOffsetY = (val(getParameterNamed("offtsetCoordinates",2))/1000) ballFinderOffsetZ = (val(getParameterNamed("offtsetCoordinates",3))/1000) coordsys = getParameterNamed("offtsetCoordinates",4) Link to comment Share on other sites More sharing options...
[Ro...] Posted March 11 Author Share Posted March 11 (edited) Hi Norbert, here u see what im getting here (ignore the parenthesis in front of val(), it doesnt change the result) And i swear, yesterday when testing the same code got me "" for coordsys = getParameterNamed("offtsetCoordinates",4) Edited March 11 Link to comment Share on other sites More sharing options...
[No...] Posted March 11 Share Posted March 11 (edited) I used the format from your original post (no "" around offsetCoordinates) and still got -0.1d for the 3rd value (-100.0). I used display() for output. Edited March 11 Link to comment Share on other sites More sharing options...
[Ro...] Posted March 11 Author Share Posted March 11 I guess im going to install the latest sp and see if it still behaves like that Link to comment Share on other sites More sharing options...
[Ro...] Posted March 11 Author Share Posted March 11 I restarted Calypso 20000 times during testing with no influence on the result. After restarting the PC to install the new sp its now working as intended Link to comment Share on other sites More sharing options...
[Ri...] Posted March 11 Share Posted March 11 Just blame Microsoft. 🤣 Link to comment Share on other sites More sharing options...
[Ro...] Posted March 12 Author Share Posted March 12 Okay, its not working again. It takes floats now, but the strings stay the same... String just become an empty string 😞 Link to comment Share on other sites More sharing options...
[Er...] Posted March 12 Share Posted March 12 (edited) Make sure you file is encoded with UTF-8, other encodings can cause issues with readListFile() and the regular filestream. If I recall correct 7.8 was the first version to use a more roboust filestream. Edited March 12 1 Link to comment Share on other sites More sharing options...
[Ro...] Posted March 12 Author Share Posted March 12 You gave me hope for a second, but unfortunately my files are encoded with UTF-8 😞 Link to comment Share on other sites More sharing options...
[Zo...] Posted 1 hour ago Share Posted 1 hour ago (edited) i might be missing something here but i created a file like yours and have the same code, just simpler got rid of "" i tried to add val() and still got same output if i divide by 1000, i get -0.1d for last value i attached my text file, try it with this and you will now if it is your file formating or calypso PCM Test.txt Edited 1 hour ago Link to comment Share on other sites More sharing options...
