Hello,
I keep getting this error when trying to export a file. In this case a mesh.
Below is the script.
gom.script.sys.export_stl (
	bgr_coding=False,
	binary=True,
	color=False,
	elements=gom.ElementSelection ({'category': ['key', 'elements', 'part', gom.app.project.parts['Part'], 'explorer_category', 'actual_part']}),
	export_in_one_file=True,
	export_stages_mode='current',
	file=gom.app.project.name + 'Example',
	length_unit='default',
	set_stl_color_bit=False)
I'm trying to get the mesh to export to the same folder location as the currently opening project. This works in some projects but not others.
Any input is greatly appreciated as always.
Many thanks
Kris
https://qualityforum.zeiss.com/topic/2608-mesh-export-python-error/
Good Morning Gents,
I will give the following a try and see if it works.
I did however find a work around by adapting another script I found on this forum. It required importing of path lib and some project keyword set up. Probably a bit long winded compared to the above but it seems to work. I've attached a link below for future reference or in case anyone else is interesting.
Many Thanks Again
Kristian Wain
https://qualityforum.zeiss.com/topic/2608-mesh-export-python-error/#findComment-6854
