Element Measuring Label
Hey,
May I get help for changing table property from symbol to characters in Scanbox report?
I want to change all
Ø
to "Diameter" in exported csv file.
Change to:
and also change DN/DT to "Nominal"
Thanks
You would need to edit table report template. But as i saw - you have to modify many things, because it's not global for every callout. Like distance, width, TP, profile, ...
I don't understand why editing table for displaying K2001 value have to be done on so many categories.
Martin,
Thanks for response. I wish to get a way to modify inspection element by displaying symbol or character in the export csv file. If so, that would be a lot of easier for user. However, I have to write a scripts to replace all those symbols in export file as dimensional team request.
I wish there could have an easy way to switch by user like some CMM software.
I have just tried export of "diameter symbol" and it was in csv - i have to just change to correct character coding.
Otherwise you would need to create own python script for exporting tables, which you have more and easier control over it.
Hi, was this exported from a table? It is possible to edit the table template. The edited table is then called in the export function in the Kiosk.
I do not unterstand this "change DN/DT to "Nominal"". If the property shows dN, there should be displayed 'Nominal'? Or is it about the arrangements of columns?
Nanno
