[Ch...] Posted 18 hours ago Share Posted 18 hours ago First off, I'm a newb on my GOM and Zeiss inspect(I'm actually using ATOS Pro v8). I'm looking for best practices for exporting XYZ points when you section a mesh. I was successful in exporting my points but I want to feel out what other people are doing. Here is my current workflow: 1. scanned the part 2. created a fitting plane to use as my reference plane 3. Used "construct single section" to create my line profile 4. Then I just used Export>ASCII file This worked but I noticed something weird. I sectioned my surface 4mm above the reference plane. But my Z value on the ASCII is at -3.27mm. The XY plot for the blade I exported looks right, so I know it exported the section I wanted. But I can't figure out why my ASCII Z values aren't closer to 4mm. To complicate it, I created a local alignment on top of the blade, I think my ASCII file might be aligned to that, but I'm not sure. To summarize: An I using the best workflow to export XYZ points from a mesh with no nominal CAD? How do I know which alignment my ASCII file is using? Link to comment Share on other sites More sharing options...
[Ma...] Posted 10 hours ago Share Posted 10 hours ago I would advise to make a Datum system - then you can export your points in correct alignment. ATOS is creating alignment from first scan where direction of a scan from ATOS to the part will be Z axis. Also you can face a problem with too many points in export. You can reduce number of points in menu Operations -> Section -> Sample sections. There is also an option in creation of that section, where you can force points by fixed distance - that works only on rough mesh - it will not reduce points, but increase points, where are big triangles. Link to comment Share on other sites More sharing options...
