[Do...] Posted March 11 Share Posted March 11 I have a bracket where I have a positional callout going back to a single datum and am curious as to what the standard practice is for setting this up. Is it something as simple as selecting the hole for the characteristic and then only selecting the opposing single datum hole under the "datum" section. Or is there some sort of specialized alignment that needs to be setup first and then referenced within the characteristic side? Our engineering group has relayed that the intent is to control the hole to the single datum hole only due to the variation that is inherent within the bending process during manufacture of the bracket. Link to comment Share on other sites More sharing options...
[Ma...] Posted March 11 Share Posted March 11 (edited) Unfortunately this is wrong selection of datums. At least one more datum should be required - i would prefer plane where is datum D. Alternatively a perpendicular plane to that plane. From this sheet you can not have strong datum to such small tolerance over that big distance. It should be better to ask engineer which of those planes are available to be a datum. Edited March 11 1 Link to comment Share on other sites More sharing options...
[Do...] Posted March 12 Author Share Posted March 12 Please sign in to view this quote. Please sign in to view this username. our engineers said that the plane that datum D lies on can be used. Does this help? Link to comment Share on other sites More sharing options...
[Ma...] Posted March 12 Share Posted March 12 Yes, then let's name that plane as datum E - so you would have |TP|Ø.028|E|D| So now evaluated hole would have to be in center of datum D, but direction will be taken from datum E. Now it will cover possibility of a mismatched hole during bending the sheet. Link to comment Share on other sites More sharing options...
[Ke...] Posted March 12 Share Posted March 12 (edited) Please sign in to view this quote. Can that plane be used? Definitely... is it the best plane to use? Probably not. With stamped/bending parts, there may be variability in the angle of that plane, that will affect the the results. Consider when these parts are run during general production: Presuming that these are stamped parts, using a progressive die - There will likely be slight changes in material thickness from coil to coil. That slight change will likely result in changes in the angle of that plane. If the angle of that plane can be tightly controlled, then it may not be an issue; but it sounds like this is not the case What are your primary Datums for the part? Edited March 12 Link to comment Share on other sites More sharing options...
[Ze...] Posted March 12 Share Posted March 12 Knowing nothing about the functionality of the part I would argue that both holes should be Datum D and whatever GD&T is controlling the one hole should control both simultaneously, especially if the intent is that both holes should be in line with each other for assembly. 1 Link to comment Share on other sites More sharing options...
[Ra...] Posted March 12 Share Posted March 12 To accomplish this to the original print, you would need to evaluate datum feature D as a cylinder, which I doubt is possible based on the image. Is the hole in question concentric to datum D? I personally would want, at the minimum, a corrected "Red-Line" drawing showing exactly what datums to use. Either from your engineers or the customer. It's a scary world when your inspection program gets audited and it's easy to prove it wasn't designed with the print intent. Much more so when you have zero documents to support you. Link to comment Share on other sites More sharing options...
[Do...] Posted March 12 Author Share Posted March 12 Please sign in to view this quote. Back face is datum A, large center hole is datum B, and the lower right smaller diameter hole is datum C. Link to comment Share on other sites More sharing options...
[Ke...] Posted March 12 Share Posted March 12 (edited) I presumed something similar to that... AIBIC obviously fully constrains the part. I also presume that what the engineer wants to use as Datum D is being evaluated to AIBIC? I would suggest making a notation on the print that the two holes are to be considered a single feature. This way, you can evaluate the two holes together as a Cylinder; so that if either hole is out of position then the part "fails" The only other way that I can think of that would make sense for this type of part, would be to constrain Datum D to AIBIC (this way AIBIC controls orientation, and Datum D would define the nominal position)... I am unsure of how this would need to be noted/called out to make it "legal" Edited March 12 Link to comment Share on other sites More sharing options...
[Do...] Posted March 12 Author Share Posted March 12 Please sign in to view this quote. Yes, the hole in question is to be in-line (concentric) with the datum D hole. Link to comment Share on other sites More sharing options...
[Ch...] Posted March 12 Share Posted March 12 ASME Y14.5 mentions datums should be of 'sufficient size', I would say Datum D single hole is insufficient size for a 'primary' 'leveling datum'. I would suggest using the outer face of D as a REF plane and measuring D as a circle, and position to those...only as a REF check, etc. Link to comment Share on other sites More sharing options...
[Ji...] Posted March 16 Share Posted March 16 It is well known that concentricity has been removed from the ASME standard. If concentricity is removed, it is expressed using position tolerance. Therefore, such a notation should be reasonable. Link to comment Share on other sites More sharing options...
[Pa...] Posted March 22 Share Posted March 22 This is totally legit but poorly engineered. With a big tolerance like this I'd have no problem using that short cylinder though I agree it's an unstable datum. This is not a CMM problem it's an engineering problem. If you're supplying this to internal customers you're pigeon-holed into figuring out how the job should have been done. If your customer is external, I strongly suggest you give them what they ask for. Use position to evaluate coaxiality. Don't move the cost burden from your customer's engineering into your CMM lab. Yes, it will fail over and over and over again. Charge them for re-runs when they get the drawing right. Link to comment Share on other sites More sharing options...
