[Fa...] Posted March 12 Share Posted March 12 Hello all, I would like to evaluate measures like principal strain, strain-rate in a certain direction over a line through the deformation scenes. I would define a line on a surface component, and I would let the software to evaluate the desired measure through this line with a desired discrete number of points, over whole deformation scenes. Is this possible? Greetings, Link to comment Share on other sites More sharing options...
[Th...] Posted 3 hours ago Share Posted 3 hours ago Hi Fatih, you can create a "Section" on a surface component. This can then be inspected for the strains and strain-rates. You can also use "equidistant pickers" on the section to create values at a given set of points. Best, Thorsten Link to comment Share on other sites More sharing options...
