[GH...] Posted March 12 Share Posted March 12 Hi all, I was able to run the program with import gom but suddenly it stopped working. Connected to Host. Link to comment Share on other sites More sharing options...
[Ma...] Posted March 13 Share Posted March 13 Hi @GHE, which ZEISS INSPECT version are you using? Link to comment Share on other sites More sharing options...
[GH...] Posted March 13 Author Share Posted March 13 @MatthiasPrinke Hi Matthias, currently I am using 2025.3. Previously I downloaded ZEISS-Quality-Suite_Installer_7.0.2778.0.exe and import gom was working initially righ after I connected with the visual studio and then stopped working. Now I change to 2025.3 because the license is 2025.3. The VS code import gom just stopped being recognized suddenly. Thank you. Link to comment Share on other sites More sharing options...
[Ma...] Posted March 13 Share Posted March 13 What i know to make this working was to make setup from VS code to api of Inspect ( ip, port, api code ) and i had to install a nuget into VS code and select correct python version. I assume that running this in several days you've tried restarting Inspect and VS code. Any logs available? Link to comment Share on other sites More sharing options...
[Ma...] Posted March 20 Share Posted March 20 I am not sure if that helps, but we have updated the zeiss-inspect-api wheels on PyPI: For ZEISS INSPECT 2025: zeiss-inspect-api 2025.4.0.398 For ZEISS INSPECT 2026: zeiss-inspect-api 2026.3.0.984 Link to comment Share on other sites More sharing options...
