[Ma...] Posted March 13 Share Posted March 13 Hi Guys, I would like to measure two identical parts in a single setup using Mini-Plan (the first part – main base, the second part – Mini-Plan). I know that this way I will get one report containing the results from both parts, but in our case we cannot use the Auto-Run option (it’s a longer story). Maybe I’ll explain how I’m doing it now: I load the second model into the program, offset by the required value. Then I copy all the elements and create a local coordinate system for the Mini-Plan from them. Finally, I copy the characteristics and assign the new elements to them. It’s a bit of a time-consuming process... Is there any way to quickly copy all the elements into Mini-Plan and automatically create characteristics from them? Thanks in advance Link to comment Share on other sites More sharing options...
[Cl...] Posted March 13 Share Posted March 13 Do you have PCM? Link to comment Share on other sites More sharing options...
[Ma...] Posted March 13 Author Share Posted March 13 Please sign in to view this quote. Unfortunately, no.. Link to comment Share on other sites More sharing options...
[Cl...] Posted March 13 Share Posted March 13 You indicated that the second part is identical? Is it a different operation? What about adding a programmable stop to remove the first part and load the second one? 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted March 13 Author Share Posted March 13 Please sign in to view this quote. Please sign in to view this quote. Link to comment Share on other sites More sharing options...
[Ma...] Posted March 13 Author Share Posted March 13 Please sign in to view this quote. I don't have experience with PCM. Do you think, it will be possible with this option? Do you have some idea for this? Link to comment Share on other sites More sharing options...
[Ma...] Posted March 13 Share Posted March 13 I think you can copy elements and characteristics, then you have to correct element name in characteristics. Now to change their nominals, you have to first make an alignment with just translation to new position. Now you can change element's alinment to new one, but first check "keep position". This will keep nominals the same, but it will move element. 1 Link to comment Share on other sites More sharing options...
[Jo...] Posted March 16 Share Posted March 16 Please sign in to view this quote. There is likely a few ways to accomplish this. With PCM, you could do a parameter program with the desired offset values as the variable. You would only need to do this for the alignment features. Add in a loop to your entire program, then do an if statement to load the parameter file depending on the loop#. This could be done without loading a parameter file, just more code. 1 Link to comment Share on other sites More sharing options...
[Cr...] Posted Monday at 10:22 AM Share Posted Monday at 10:22 AM Please sign in to view this quote. currently trying to figure out how to add a programmable stop. help? Link to comment Share on other sites More sharing options...
[To...] Posted Monday at 03:24 PM Share Posted Monday at 03:24 PM Here's a tidbit regarding mini-plans. If you select a group to be in a mini-plan, you can drag other characteristics into the group and they become part of the mini-plan. 1 Link to comment Share on other sites More sharing options...
[Ra...] Posted Monday at 03:37 PM Share Posted Monday at 03:37 PM Please sign in to view this quote. In feature strategy. 1 Link to comment Share on other sites More sharing options...
