Export histogram
Hi,
Is there a way how to export a histogram of deviations, for example for Inspection section of for Surface comparison?
The only related thing (at least by the name) I found in Script objects is "discrete_histogram_table", but I'm not exactly sure what type of object it is and how to work with that. Another option would probably be a "Scalar value of element" object, that should give me scalar values of the deviation for each point of the section, but when I try to export the values of this nparray, it gives me zeros (see attached image).
Any idea, how to get either histogram data or the deviation data of the section?
Thanks
Tomas
Hello Nanno,
thank you for your reply. Can you please explain in more detail what element do you mean and what "Deviation" box should be checked?
Thank you
Tomáš
Hello Nanno,
I would like to remind myself with the plea for more detailed explanation for the terms mentioned in your reply.
Thank you
Tomáš
