[Cl...] Posted 23 hours ago Share Posted 23 hours ago (edited) I created a new tab in planner. Opening a program, I checked the MasterProbe geometry and its wrong? Wrong vector direction and no radius? Edited 23 hours ago Link to comment Share on other sites More sharing options...
[To...] Posted 23 hours ago Share Posted 23 hours ago Not a new situation. I always edit the R to 2.5 and move on. Doesn't seem to come into play until you start defining holder locations on your probe rack. Link to comment Share on other sites More sharing options...
[Cl...] Posted 22 hours ago Author Share Posted 22 hours ago What about the vector? I can't edit that. Link to comment Share on other sites More sharing options...
[Je...] Posted 7 hours ago Share Posted 7 hours ago At my planner seat with vast XTR I can change the vector.. but you can try with PCM: setNewGeoStatToActualProbe(0,0,0,0,0,-1) setNewRadiusToActualProbe("2.5") that should work Link to comment Share on other sites More sharing options...
[Cl...] Posted 3 hours ago Author Share Posted 3 hours ago Thank you Jens. Where do I insert this code? Link to comment Share on other sites More sharing options...
[Je...] Posted 3 hours ago Share Posted 3 hours ago (edited) Please sign in to view this quote. make sure, that you have the needed probe changed in do you have pcm? plan->Advanced->PCM Editor copy the code into the editor, mark it, and press the calculate-button (an arrow inside a gear-wheel) without pcm you can write a small program (with your master probe) with two characteristics with conditions. in them just write something like setNewGeoStatToActualProbe(0,0,0,0,0,-1)=="GG" and setNewRadiusToActualProbe("2.5")=="gg", select "yes" for end program, and run that program offline Edited 2 hours ago Link to comment Share on other sites More sharing options...
[Cl...] Posted 1 hour ago Author Share Posted 1 hour ago Success! Thanks again Jens! Link to comment Share on other sites More sharing options...
