Loading a Stylus System mid program inside the part
I will be working on a program on a pretty big part, 600mm long. The part is a rolled shell with side ledges that I need to measure roughly 400mm inside.
The problem is our CMM is not long enough to clear the part within the CMM limits on the long probe I developed.
Here is my plan to overcome this...
1. Start the program using a shorter probe for alignments.
2. Return the probe to the rack.
3. Move the machine head to the front of the part at the "load/unload location."
4. Manually load the new long probe.
5. Measure all internal features with the new long probe.
6. Return to the probe "load/unload location."
7. Manually unload the long probe.
8. Perform an automatic probe change and continue measuring the rest of the program.
How should I approach this? I do have PCM. I need advice for #3, 4 & 7.
Appreciate the help!
