[CA...] Posted 23 hours ago Share Posted 23 hours ago (edited) Good afternoon, folks. Just started using the GDT Engine in Calypso 2023 (7.6.20) and am having some reporting issues. I was able to find the work-around to get rid of the additional diameter report line, but the icons for perp, parallel, cylindricity and position are not showing on the report. Instead, there is a pictogram of a sheet of paper... Is this a setting or something I need to change, am I missing something or is this an issue anyone else has seen? Thanks in advance for any and all input. I have faith that the people on this forum will have an aswer. Edited 23 hours ago spelling errors Link to comment Share on other sites More sharing options...
[CA...] Posted 23 hours ago Author Share Posted 23 hours ago Side note: All the new gdt engine icon DO show up in the characteristics tab, just not on the PiWeb report Link to comment Share on other sites More sharing options...
[Lu...] Posted 23 hours ago Share Posted 23 hours ago Hello Casey, I believe this behavior is expected in CALYPSO 2023. I tested this on my system and receive the same icons in the PiWeb report. Please keep in mind that the GD&T engine is a beta version in CALYPSO 2023. I hope this helps even though it might not be the answer you are looking for. Link to comment Share on other sites More sharing options...
[CA...] Posted 22 hours ago Author Share Posted 22 hours ago Thanks Lucas. Pending further input, I'll chalk it up to Beta and see if it corrects when we upgrade next. Link to comment Share on other sites More sharing options...
[Ri...] Posted 17 hours ago Share Posted 17 hours ago Yes this was corrected in Calypso 2024 and beyond. Also note that there was a huge change in the way the DRF was built inside of the GD&T engine in 2023 and 2024+. Mainly it is in the fact that no matter what orientation the program was in, the 2023 engine built the DRF in the X/Y plane, but 2024+ tried to retain the original orientation, so if you open a program in 2024+ that was built in 2023 be prepared to update the nominals of the Position characteristics. Link to comment Share on other sites More sharing options...
