[Li...] Posted Monday at 07:56 PM Share Posted Monday at 07:56 PM I am working in Calypso 2025. I have a variable I created called u_Work_Order. I have enabled this parameter under Run and Measurement for my report header. I have also enabled Force Input at Start. A pop-up box appears right after the user hits run that asks them to enter in the WO. I would like to validate that the WO they entered is exactly 10 characters. I have been told I need to use PCM for this. I have tried creating my PCM program two different ways: first is by placing the code in a .txt file and then placing it in the root of the measurement plan program. I have also tried placing the code in the pre-settings with a global scope. I have tried every possible variation of code. Below are some I have tried. I always get an error like u_Work_Order is not defined or Temp_Variable is not defined. u_wo_number = "" repeat u_wo_number = inquireText("Please enter 10-digit WO Number") if len(u_wo_number) != 10 then message("Error: Must be 10 characters. You entered: ", len(u_wo_number)) endif until len(u_wo_number) == 10 u_wo_number = "" while len(u_wo_number) != 10 do u_wo_number = inquire( "Please enter 10-digit WO Number" ) if len(u_wo_number) != 10 then display( "Error: Must be 10 characters. You entered: ", len(u_wo_number) ) endif endwhile u_wo_number = "" while len(u_wo_number) != 10 do u_wo_number = inquireText("Please enter the 10-digit WO Number:") if len(u_wo_number) != 10 then message("Error: The WO number must be exactly 10 characters. You entered ", len(u_wo_number)) endif endwhile message("WO ", U_wo_number, " accepted. Starting measurement.") Link to comment Share on other sites More sharing options...
[Ri...] Posted Wednesday at 02:31 PM Share Posted Wednesday at 02:31 PM The not comparison is <> for PCM. Link to comment Share on other sites More sharing options...
[Ri...] Posted Wednesday at 02:32 PM Share Posted Wednesday at 02:32 PM Be careful with Repeat commands because you do not have a break condition, so it will run indefinitely. Link to comment Share on other sites More sharing options...
[DW...] Posted Wednesday at 06:14 PM Share Posted Wednesday at 06:14 PM (edited) Please sign in to view this username. GPT gives me this: wo = getRecordHead("u_Work_Order") IF STRLEN(wo) <> 10 THEN MESSAGE("WO must be exactly 10 characters.") STOP ENDIF Since the variable (wo) already exists ("u_Work_Order", entered manually at Run), you just need to validate it, not ask for it again. I do not have PCM to verify (might not be STOP, I think it is CNCBreak()?), but the logic makes sense. Been quite awhile since I have used PCM. From this core code, you can expand on it and enforce more rules (for instance, not allowing someone to just type '0000000000' 🤣) Edited Wednesday at 06:17 PM Link to comment Share on other sites More sharing options...
[Ri...] Posted Wednesday at 06:28 PM Share Posted Wednesday at 06:28 PM endInspection() is better than cncBreak(). cncBreak will redlight the machine. There are cases though where cncBreak is the only thing that will stop a loop though. 1 Link to comment Share on other sites More sharing options...
[Ch...] Posted 16 hours ago Share Posted 16 hours ago you're definitely on the right path, just remember Calypso uses it's own version of small talk programming language. Your code appears right for python and similar languages, I haven't yet got GPT to spit out any useable smalltalk code for Calypso. I no longer have PCM access directly otherwise I would test it out for you. Link to comment Share on other sites More sharing options...
