Separate evaluation methods for recalled features?
Hello, I was trying to create a 3d line between an inside diameter and an outside diameter. In the recall menu I see the box where you select the evaluation methods for the feature you recall, but I would want to use Max inscribed on the inside diameter, and Min circumscribed for the outside diameter, and i am having difficulties being able to tell if it is applied to both correctly or not. It seems like the selected evaluation method applies to both features recalled. I was wondering if there was a way to make sure there is a different evaluation method being used for each recalled feature into that 3d line. If my description is confusing I can take photos if that helps. Thanks!
There should be option for outside and inside instead of inscribed/circumscribed - that meanes it should do always tangential element as functional.
Otherwise you would need to create duplicate and set them correctly.
Also you can try it out with duplicates and look which setup fits observation.
  • Like! 1
