[Fa...] Posted April 1 Share Posted April 1 Hello, I would like to perform a derivative operation on an array. The first array is the values of a dimension. The second array is the time. How can I perform delta_Y / delta_time? It would also be great if is there a guide for writing valid actual expressions in GOM. Link to comment https://qualityforum.zeiss.com/topic/26272-how-to-perform-a-derivative-operation-on-arrays/ Share on other sites More sharing options...
[Th...] Posted May 4 Share Posted May 4 Hi Fatih, whats your goal / application here? Maybe we can find a built-in solution?! Otherwise maybe this helps: https://zeiss.github.io/zeiss-inspect-app-api/2026/howtos/scripting_solutions/scripting_solutions.html#scripted-checks Best regards, Thorsten Link to comment https://qualityforum.zeiss.com/topic/26272-how-to-perform-a-derivative-operation-on-arrays/#findComment-150044 Share on other sites More sharing options...
