Alignment using pattern for rotation
If you are using the new GD&T engine Datum C would be a Common Datum, you will see the button inside of the feature selection.
If you are creating this via the legacy GD&T engine you will need to create a Bore Pattern Best Fit - when Calypso creates a BPBF it will create a new alignment for you that you can use for other characteristics.
Hi
I'm curious:  why do you need to set up a rotational pattern for the base alignment?
The purpose of a base alignment is primarily to facilitate navigation of your probing system and provide basic stability for the measurement plan. Typically, secondary alignments and features utilize rotational patterns for position characteristics.
I agree with Jeff. I honestly use the base alignment more as a start alignment. I never use it in any characteristics. I'd just use one of the holes for C datum for the base alignment, then refine it properly later.
