[Ro...] Posted April 3 Share Posted April 3 What is the difference between an intersection and a projection of a cylinder onto a plane? A program I am working on is using a projection to a plane to get the true position of a bore at a compound angle. I have not seen that before, and personally would have used an intersection to said plane. I ask because I get very different results when using one vs the other. Link to comment Share on other sites More sharing options...
[Ri...] Posted April 3 Share Posted April 3 I believe that the biggest difference with projection is the order in which it is set, so make sure you aren’t actually projecting the plane to the cylinder. 2 Link to comment Share on other sites More sharing options...
[Ro...] Posted April 6 Author Share Posted April 6 I believe the order of the projection is correct, but the results for position are quite different. If I choose the cylinder for the position then choose projected tolerance zone, and choose the plane for Feature 1, and set offset and reference length to 0, I get very similar results, less than 10 microns, compared to using the intersection of cylinder to plane, so I believe the intersection is the correct way to do it. I just was curious to why the cylinder projection is so much different. Link to comment Share on other sites More sharing options...
[Ke...] Posted April 6 Share Posted April 6 Please sign in to view this quote. Perhaps the Intersection is translating along the Cylinder axis (until it intersects the Plane); whereas, the projection is just using the origin (or centerpoint) of the Cylinder and (looking for a different word besides "projecting" 😂)...projecting it directly to the Plane Link to comment Share on other sites More sharing options...
[Ro...] Posted April 6 Author Share Posted April 6 Please sign in to view this quote. Yea, after more thought, that is the conclusion I have come up with as well. Link to comment Share on other sites More sharing options...
[Ri...] Posted April 6 Share Posted April 6 Intersection would be projected along the axis of the cylinder normal to the axis of the cylinder until it hit the surface you told it to intersect.  Projection would be taking the axis of the cylinder and projecting it along the axis of the cylinder normal to the axis of the surface you told it to project to.  if the two surfaces aren’t very square to each other then you would see vast differences. Link to comment Share on other sites More sharing options...
[Ka...] Posted April 7 Share Posted April 7  That’s a very clever question! Is that really the case? Is the projection point the point where the axis of the cylinder intersects the projection plane? Is the point of intersection the point where a line perpendicular to the projection plane intersects the MIDDLE of the cylinder’s axis?  What is completely unclear to me is the position of a cylinder in general. This is because the question arises as to which point on the axis of a cylinder is used to determine its position.  1 Link to comment Share on other sites More sharing options...
[Da...] Posted April 7 Share Posted April 7 Projecting a cylinder onto a plane results in a line, similar to a sundial. Link to comment Share on other sites More sharing options...
[ni...] Posted April 8 Share Posted April 8 point of intersection vs line of projection 2 Link to comment Share on other sites More sharing options...
