Options for changing the color map
Hello,
Are there any options in ARAMIS or Correlate for changing the color bar beyond the built in GOM continous/8 colors/3 colors options? If anyone has any experience to share related to customizing the color bar potentially to create something like the ones listed here (https://colorcet.com/) that would be great to know.
Thanks,
Hi.
Yes you can change it "fine tune it " for your needs 🙂
Press RMB on the Legend and chose Edit Legend.
You will see lock signs (built in legend display settings)
You need to create an user one:
Than lock sign will change to user head.
And than  you may create your own settings
MK
