[Ro...] Posted April 6 Share Posted April 6 Hello, all. I am asking this question on behalf of the IT personnel since I have Zeiss Portal access. I am due to receive a new laptop as our company is obsoleting all devices that cannot run Windows 11, and I am getting an upgrade. They are encountering an issue when trying to register my dongle onto the new computer, the error reads "Supplied IDs are not activatable" and "Product Key xxx.... has already been activated". Is there a step we are missing to get the license transferred to the new computer? Thanks in advance for any insight. Link to comment Share on other sites More sharing options...
[Na...] Posted April 8 Share Posted April 8 Hi Ronnie, please contact your local support (see Links -> Contact at the top of the forum) with your license information. The license needs to be reset so you can activate it on a new device. Nanno Link to comment Share on other sites More sharing options...
[Sv...] Posted April 10 Share Posted April 10 On your old computer, go to C:\ProgramData\Zeiss License. Copy the license files from there. Then, on your new computer, insert the dongle and reactivate the files using the Zeiss License Management Tool. 2 Link to comment Share on other sites More sharing options...
[Br...] Posted April 15 Share Posted April 15 I would suggest what Sven said above. Its the Zeiss license.zlic file that you want. Make sure you import it and just not paste it in that directory. That used to work at one time, but no longer does. Link to comment Share on other sites More sharing options...
[Ca...] Posted May 7 Share Posted May 7 What Sven and Bruce suggested will work for dongle licenses. Here is a step by step guide if anyone runs into this same issue and needs it: https://portal.zeiss.com/knowledge-base?id=1517958 Here is also a document that may help with the other information you will want to bring between computers as well: https://portal.zeiss.com/knowledge-base?id=444235 Link to comment Share on other sites More sharing options...
[Pa...] Posted June 14 Share Posted June 14 2 things: 1. IT can have their own portal access. It's easy and free and the only correct way to do this. 2. once IT has access, they will use a system of helpdesk tickets to resolve all issues. You've got other stuff to do. Link to comment Share on other sites More sharing options...
