[St...] Posted Tuesday at 07:05 PM Share Posted Tuesday at 07:05 PM Hello, I have added inspection post load batch files to each main Zeiss program folder that automatically opens the setup instructions when the main program file first loads in the main Calypso software. Unfortunately, this does not work when using Autorun. When using a multiple station pallet, it extremely important to have the instructions open right away in order to assist the operator in loading the parts to be measured correctly into each pallet location, and to be able to X out any pallet locations that will not have a part loaded. Currently with Autorun, the setup instructions look to open only with the "Force measurement run information at CNC start" box checked in the Measurement Plan Definition. With the box checked, it requires the Run icon to be clicked by the operator for the instructions to load and open. The setup instructions will load and open automatically after Run is clicked, but that is too late as it now requires the operator to perform extra steps that should not be needed. The main issue I see is with the CNC Run Stopped screen that opens when Run is clicked: This screen being open blocks access to turn on/off the pallet locations. The only way to get back to the pallet is to Cancel Run, which causes the stoplight to turn red. This in turn forces the operator to have to reset the stoplight to green in order to continue. While it is good that the setup instructions are now open and the operator can now follow these to load the parts into the pallet locations (and turn off any location not used), it requires needing to again click the Run icon, have the CNC Run Stopped screen pop up again, then click Continue Run to finally bring up the input parameter screen for the active pallet locations and get the program to actually start measuring parts. This should not have to be so complicated just to get setup instructions to load right away when the Autorun file is loaded. I have searched through this forum for a workaround but have been unsuccessful. The only hints I have found are tied to PCM, which I do not have. I need setup instructions to load right away when the Autorun file first loads. Any assistance would be greatly appreciated. Link to comment Share on other sites More sharing options...
[na...] Posted Wednesday at 06:50 AM Share Posted Wednesday at 06:50 AM Please sign in to view this quote. I haven't tested, but you might be able to do it with inspection_post_load_pcm.txt external PCM file (no PCM license required). Check Calypso help (F1), search for Reference: Names of external PCM files Link to comment Share on other sites More sharing options...
[St...] Posted Wednesday at 02:51 PM Author Share Posted Wednesday at 02:51 PM Thank you for response. I will look into this at first opportunity. Hopefully this is the workaround that is needed. Link to comment Share on other sites More sharing options...
[Ka...] Posted 11 hours ago Share Posted 11 hours ago Please sign in to view this quote. hi na_vor, We have no PCM but your answer let me hope we can use generic PCM functions anyway... I have no special idea of PCM but I´m familar with some programming languages like C, Perl, ksh ... I read the the file plugin_postFeature_pcm.txt is read before output parameters of a measurement are executed. So for my understanding this file is parsed after every Measurement. In that, I insert a simple SystemCall("write_mylog.bat") to this file in hope it will be executed for every measurement. But I see it is only executed once 😞 My Idea: Sometimes we need to use the programmable stop. For better understanding what the user has to do I would like to display a little picture using the feature "Measurement information". Unfortunately this call is "sticky" which means the executed viewer will not closed after the user press "go on with CNC" button. If I get a "user-exit" after the measurement, I can kill the called process just after the related measurement is done. Link to comment Share on other sites More sharing options...
