[Do...] Posted 7 hours ago Share Posted 7 hours ago Try as I might, I cannot seem to get my group to pattern properly. My goal is to measure the teeth around the OD of a part using a rotary table. Currently, the program is set to measure the left flank, right flank and depth in a pattern (i.e. it measures left flank of tooth one then left flank tooth two and so on then after all left flanks are done it measures right flanks). What I would like to do is capture all relevant features of each tooth before each rotation. In my mind this would be more efficient as I can use subclearance planes instead of the full clearance cube in the pattern. I've created additional alignments for each section and activated rotary table, but the part in simulation does not rotate and I receive collision errors as a result. I'm sure I am missing some minor detail to get this to work. Thoughts? Link to comment Share on other sites More sharing options...
