[Do...] Posted Tuesday at 08:53 PM Share Posted Tuesday at 08:53 PM Try as I might, I cannot seem to get my group to pattern properly. My goal is to measure the teeth around the OD of a part using a rotary table. Currently, the program is set to measure the left flank, right flank and depth in a pattern (i.e. it measures left flank of tooth one then left flank tooth two and so on then after all left flanks are done it measures right flanks). What I would like to do is capture all relevant features of each tooth before each rotation. In my mind this would be more efficient as I can use subclearance planes instead of the full clearance cube in the pattern. I've created additional alignments for each section and activated rotary table, but the part in simulation does not rotate and I receive collision errors as a result. I'm sure I am missing some minor detail to get this to work. Thoughts? Link to comment Share on other sites More sharing options...
[Do...] Posted yesterday at 01:13 PM Author Share Posted yesterday at 01:13 PM Update Things I've tried so far include: 1. Create a pattern of the group - Rotational pattern for scallop: This creates a pattern for each point, however, Calypso sets the run order to measure all point 1's around the part followed by point 2, etc. Even using the optimal navigation tool, the set order still ends up the same. 2. Copy the points - Copying the points into a new group and assigning them to a new rotated alignment (rotary table activated). The graphic shows the points are moved to the right location, however, the rotary table is not moving to keep the position in X+. I've tried the "keep position" option and re-assigning to the base alignment which has the probe measure in the same location, albeit the rotary as well. Link to comment Share on other sites More sharing options...
[Do...] Posted 23 hours ago Author Share Posted 23 hours ago Solution: Working more on option two I was able to get the desired result by setting the "Angle of rotary table" under Resources > Features settings editor to each specified angle around my pattern. Used in conjunction with the defined alignments at the same angles, the program is now keeping the point grouping as the part rotates and adhering to the sub-clearance planes I specified. 2 Link to comment Share on other sites More sharing options...
[Ch...] Posted 20 hours ago Share Posted 20 hours ago clever, well done. I think there may be other ways including 'formula then pattern', as well as LOOP. Link to comment Share on other sites More sharing options...
