Table filtering
Hello,
Is it possible to hide table rows which are based on the calculated value? I want to show only rows which have 1.000 (green rect), the rest with 0.000 (red cross) should be hidden.
I use advanced filter by expression and I use the name for this column "filtr" but it doesn't work:
${Equal(Value("filtr"), 1)}
Filtering by characteristisc within or out of tolerance works.
I also created my own variable (filter) and changed 1.000 with 'yes' and 0.000 with 'no' and use the expression:
${List.Contains(filter, "yes")} also doesn't work.
