[Do...] Posted 3 hours ago Share Posted 3 hours ago Has anyone ever encountered a scenario where you have a CMM fixture that locates the part on the physical datums and has tooling balls located on the fixture for CMM pickup? In this situation how do you program the part so that it aligns properly and can provide measurements that correlate back to the required datums if you are not able to physically probe the actual datum features? Secondly, has anyone encountered a situation where the CMM fixture located on the physical datums, preventing actual probing, and it did not have tooling balls for CMM pickup? How do you program the part from this setup? Lastly, is there any literature out there that is available that helps describe and provide detailed steps on how to develop CMM programs where you have to use tooling balls for part alignment and measurement? Link to comment Share on other sites More sharing options...
[Ch...] Posted 3 hours ago Share Posted 3 hours ago You can put in a programable stop and take the part out of the fixture and then measure on the datum locators. Link to comment Share on other sites More sharing options...
[Do...] Posted 3 hours ago Author Share Posted 3 hours ago Please sign in to view this quote. How would you do it if you had tooling balls? Link to comment Share on other sites More sharing options...
[Ke...] Posted 55 minutes ago Share Posted 55 minutes ago The CMM fixture(s) that I had to use that had tooling balls also had XYZ coordinates for those tooling balls, and I used those in a 3D Best Fit Base Alignment. For those parts, the results were reported "in-body position" (automotive), so the datums themselves did not need to be measured... I suppose that if the tooling balls do not have xyz coordinates, you can measure the fixtures simulated datum features as the Base Alignment and then report the xyz of the tooling balls, yourself (definitely need to be sure of your measurements/repeatability). However, I would think that the fixture manufacturer should be able to provide those tooling ball coordinates for you(?) Link to comment Share on other sites More sharing options...
