Circular Points
Hello everyone,
I would like to figure out, if its possible to create 12 uniformly distributed points on a surface along a circle of Ø75,5mm.
I'd be very happy if there is anyone, who can help my finding a solution.
Best regards
Dominik Walle
Hi Dominik,
it is possible with create cluster -> copy cluster ZEISS Quality Tech Guide
I created the first point as an offset point of the circle (offset = radius). The circle is then used as rotation axis for the cluster copies.
If it's a more curved surface, an approach might be to create a surface curve first and then create 12 intersections from plane-curve for example.
Nanno
  • Like! 2
  • Thank you! 1
