[Ne...] Posted 9 hours ago Share Posted 9 hours ago Hello I’m looking for guidance on scripting in ZEISS INSPECT + Kiosk, specifically around the inspection execution lifecycle. I’m trying to understand the correct scripting/API approach for the following: setting the parameters for an inspection identifying the exact point where the actual inspection/evaluation starts determining exactly when that process has finished collecting/extracting the resulting inspection values More specifically, I want to know: What is the recommended entry point in ZEISS INSPECT scripting for starting an inspection or evaluation? Is the start call synchronous or asynchronous? If asynchronous, what is the recommended way to detect completion: polling status callback/event hook kiosk workflow hook other mechanism What API objects/functions should be used to read the final results after completion? Are there example scripts or documentation pages that demonstrate this full flow: set parameters start inspection/evaluation wait for completion read/export results If there is official documentation, API reference material, or example scripts covering this workflow, I’d appreciate being pointed to them. Thank you, Neta Link to comment Share on other sites More sharing options...
[Ma...] Posted 6 hours ago Share Posted 6 hours ago Only documentation is this ( depending on your version of Inspect ) Inspect 2026 Inspect 2025 List of other versions Link to comment Share on other sites More sharing options...
