[AG...] Posted April 20 Share Posted April 20 When i run a program the PiWeb report is visible for about 10 seconds and then it disappears. It is not on my task bar either, so i have to go in and go up to View and Multiple Report to bring it back up to view and save. Is there something that i am missing to keep the Report up and not disappear? Thank you for any information on this. Link to comment Share on other sites More sharing options...
[Ma...] Posted April 20 Share Posted April 20 Minimize Calypso and it will popup again - but it's strange behaviour which i see often too Link to comment Share on other sites More sharing options...
[DW...] Posted April 20 Share Posted April 20 Please sign in to view this quote. Please sign in to view this username. As far as I am aware, the only actions that will automatically close the PiWeb report are saving the Calypso program, or if a subsequent PiWeb report is generated. Some things to poke around for - Any PCM calls at the end of the program? Any files (global or local) named measurement_end_pcm.txt, calculation_end_pcm.txt, inspection_end_pcm.txt, or report_end_PCM.txt that are causing the PiWeb closure through PCM? At then end of the program, when the popup shows "Report generating" or whatever it says, can you snapshot this before it closes and post that snapshot here? Is this new behavior or has it always been this way? Link to comment Share on other sites More sharing options...
[AG...] Posted April 20 Author Share Posted April 20 Please sign in to view this quote. I tried this and it didnt work for me. Link to comment Share on other sites More sharing options...
[AG...] Posted April 20 Author Share Posted April 20 Please sign in to view this quote. Link to comment Share on other sites More sharing options...
[AG...] Posted April 20 Author Share Posted April 20 Please sign in to view this quote. It has always been like this. I am wanting to see if anyone else is experiencing the same thing i am. And how they might have fixed it? Link to comment Share on other sites More sharing options...
[Ri...] Posted April 21 Share Posted April 21 I am experiencing this on v2022. I just reload the multi report. What I also have and is more frustrating, is PiWeb report will come up blank until I use F7. Link to comment Share on other sites More sharing options...
[Ch...] Posted April 21 Share Posted April 21 I also have this issue. I use ALT-TAB to scroll through the open windows. Just keep hitting alt-tab until the pi-web report is highlighted and let go. It will pop back up.l Link to comment Share on other sites More sharing options...
[AG...] Posted April 23 Author Share Posted April 23 Please sign in to view this quote. I tried this and if i dont use ALT-TAB right away and bring it up after it disappears. Then it is no longer there. Thank you for the information to try. Please sign in to view this quote. I am drawing a blank on how to reload multi report? When you reload it does it stay up on the screen. How long after that do you have to reload multi report again because it keeps going away? It's frustrating for sure, i guess i am to the point of wanting to make it stop because i have been working with this for 2 years now. Thank you for the information to try out. Link to comment Share on other sites More sharing options...
[Ri...] Posted April 23 Share Posted April 23 (edited) In the top menu select View Then select Multiple Report This will regenerate the PiWeb report. One thing to remember, if you have opened any characteristics, the regenerated report will only reflect the characteristics viewed. If that happens, you have to cycle thru all characteristics, re-run the part with "Clear existing results" turned off. Edited April 23 Link to comment Share on other sites More sharing options...
[AG...] Posted April 23 Author Share Posted April 23 Please sign in to view this quote. Yes, that is what i have been doing for so long is going into View and Multiple report and bring it back up. My bad, i was thinking you were talking about reloading the whole PiWeb report, like the Standard Protocol one that i am using currently. This is why the frustration has set in having to go in and reload the Multiple Report again. 1 Link to comment Share on other sites More sharing options...
[An...] Posted 15 hours ago Share Posted 15 hours ago Please sign in to view this quote. Do you have auto fetch data on? Link to comment Share on other sites More sharing options...
[Ri...] Posted 2 hours ago Share Posted 2 hours ago Please sign in to view this quote. I will have to check that; I am not sure how it would have been turned off. Link to comment Share on other sites More sharing options...
