[Gl...] Posted April 20 Share Posted April 20 Hello ya'll, I was in need of a tool to mass create inspection points. I am using Zeiss Correlate on Photogrammetry data. I am using target markers. My projects all contain around 20 components, and the total target count is ~250. I could not find a way to get XYZ position data without creating inspection points, and I could not find a way to mass create these points through the Correlate program, so I created this app. I hope this helps someone else. If you know of something I could improve, or an easier way to achieve this - I am open to suggestions. I get the feeling that there is a button somewhere in the program for this already, because it seems like this would be a useful feature. Thank you! import gom array1 = gom.app.project.actual_elements array1 = sorted(array1, key=lambda e: str(e)) # Constructs and their number of points must be the same between projects, otherwise inspection point numbering will differ. for name in array1: if str(name) == "gom.app.project.actual_elements['actual_master']": continue if str(name) == "gom.app.project.actual_elements['all_measurement_series']": continue if str(name) == "gom.app.project.actual_elements['all_reference_points']": continue if str(name) == "gom.app.project.actual_elements['Analog input 0']": continue if str(name) == "gom.app.project.actual_elements['Analog input 1']": continue if str(name) == "gom.app.project.actual_elements['Analog input 2']": continue if str(name) == "gom.app.project.actual_elements['Analog input 3']": continue if str(name) == "gom.app.project.actual_elements['Analog input 4']": continue if str(name) == "gom.app.project.actual_elements['Analog input 5']": continue if str(name) == "gom.app.project.actual_elements['Analog input 6']": continue if str(name) == "gom.app.project.actual_elements['Analog input 7']": continue if "Point" in str(name): print("Operation Complete. Ending Script.") break print(name) print(name.data.coordinate.shape[1]) points_total = name.data.coordinate.shape[1] for x in range(points_total): if name.data.coordinate[0][1] is not None: try: MCAD_ELEMENT=gom.script.inspection.inspect_by_point (point={'id': x, 'target': name, 'type': 'coded'}) except Exception as e: print(f"Skipping {name}: {e}") continue Link to comment https://qualityforum.zeiss.com/topic/26409-bulk-point-inspection-app/ Share on other sites More sharing options...
[Ma...] Posted April 21 Share Posted April 21 I would suggest to place a keyword into that element so you can then make for cycle where you scan all elements for your keyword ( it will fail, when there is no such keyword, so place it into TRY/EXCEPT, with "pass" in exception ) Now you don't need to manually place names into condition 1 Link to comment https://qualityforum.zeiss.com/topic/26409-bulk-point-inspection-app/#findComment-149399 Share on other sites More sharing options...
[De...] Posted April 24 Share Posted April 24 You should just be able to select the point component & File-Export-StageData-CSV 1 Link to comment https://qualityforum.zeiss.com/topic/26409-bulk-point-inspection-app/#findComment-149623 Share on other sites More sharing options...
[Gl...] Posted May 7 Author Share Posted May 7 Appreciate the info! Is there a way to export that way using the local coordinate system? Please sign in to view this quote. Link to comment https://qualityforum.zeiss.com/topic/26409-bulk-point-inspection-app/#findComment-150312 Share on other sites More sharing options...
