[Ti...] Posted April 30 Share Posted April 30 We have a Zeiss ACURA CMM that has started shutting the drives off for no reason. We have 3 CMM'S in the lab attached to the same air supply but this is the only one giving us a issue. Looking for ideas before I call support. Thanks Link to comment https://qualityforum.zeiss.com/topic/26504-drives-shutting-off/ Share on other sites More sharing options...
[Ma...] Posted May 4 Share Posted May 4 It happens durin CMM motion or when it is at statndstill ? If you have to reset CMM to enable drives then it is measuring system error. Any error message in Calypso log window ? Link to comment https://qualityforum.zeiss.com/topic/26504-drives-shutting-off/#findComment-150052 Share on other sites More sharing options...
[Ab...] Posted June 8 Share Posted June 8 Hello i would recommend making a ticket so a HW tech can troubleshoot to see if there is any issue in machine. in meantime you can also check some stuff to make sure everything is running ok https://portal.zeiss.com/knowledge-base?id=571558 Link to comment https://qualityforum.zeiss.com/topic/26504-drives-shutting-off/#findComment-151560 Share on other sites More sharing options...
