[Lu...] Posted yesterday at 12:09 PM Share Posted yesterday at 12:09 PM Hi, I would like to know how it is possible to implement a loop for a second alignment (not the base alignment). For the base alignment, we use the condition baseSystem().valueA < 0.005. How can something similar be implemented for this second alignment? Link to comment Share on other sites More sharing options...
[Ke...] Posted yesterday at 12:29 PM Share Posted yesterday at 12:29 PM "differenceSystem()" for secondary 1 Link to comment Share on other sites More sharing options...
[CA...] Posted yesterday at 01:04 PM Share Posted yesterday at 01:04 PM Please sign in to view this quote. So, right click to access the loop option of the secondary and use differenceSystem in the condition? Simple. Great to know thanks to Luca for the ask and thanks to Keith for the answer. Link to comment Share on other sites More sharing options...
[Ri...] Posted yesterday at 01:22 PM Share Posted yesterday at 01:22 PM Doesn't the differenceSystem() essentially check the difference of the alignment to the main alignment? I felt like when I tried to use it years ago it always showed large values, so if it was a completely new origin, you will never achieve what you want/need. 1 Link to comment Share on other sites More sharing options...
[Th...] Posted 23 hours ago Share Posted 23 hours ago Please sign in to view this quote. That or there's no iteration of the calculated alignment. Either way, I don't believe valueA on a secondary alignment ever changes with loops. Link to comment Share on other sites More sharing options...
[Mi...] Posted 6 hours ago Share Posted 6 hours ago Link to comment Share on other sites More sharing options...
[De...] Posted 1 hour ago Share Posted 1 hour ago I ran across this document a while ago somewhere on the forum. On page three, there are notes on how the differenceSystem should be used to evaluate a proper break condition. differenceSystem does not converge to zero, like baseSystem. It's an interesting read. ValueA Math Definition.docx Link to comment Share on other sites More sharing options...
[De...] Posted 1 hour ago Share Posted 1 hour ago Here is the PCM we use based on the above document, including a display command to allow operator to insure convergence. differenceSystem correct usage - Copy.docx 1 1 Link to comment Share on other sites More sharing options...
