[Do...] Posted 2 hours ago Share Posted 2 hours ago Peculiar. Ryan, are you using a start alignment in the program by chance? Link to comment Share on other sites More sharing options...
[Ry...] Posted 2 hours ago Author Share Posted 2 hours ago Please sign in to view this username. I am not the only alignment that is set up in the program is the base. I have a call into Zeiss the machine has since started doing other strange things and I fear I have sensor going out. Link to comment Share on other sites More sharing options...
[Do...] Posted 2 hours ago Share Posted 2 hours ago Understandable. One last suggestion (which you may have already tried) is power cycling the machine and your PC. Many an issue has been cleared from a hard reset for me over the years. Best of luck and hope you get your issue resolved soon. Link to comment Share on other sites More sharing options...
[Ry...] Posted 2 hours ago Author Share Posted 2 hours ago Please sign in to view this quote. I power cycled the computer but I have not the machine I will have to try that Link to comment Share on other sites More sharing options...
[Ch...] Posted 33 minutes ago Share Posted 33 minutes ago Please sign in to view this quote. Please sign in to view this username. When using the XTR, its very possible that a probe is qualified at the wrong rotation. Check you stylus geometry screen to make sure everything is as you would expect it. For example, a probe facing +x could have been qualified in the -Y direction. I've had operators screw this up in the past. My second point: There is absolutely nothing wrong with using circles for setting rotation. Link to comment Share on other sites More sharing options...
