Change Alignment Heirarchy in GOM by script
Posted (edited)
My project have 100's of BestFit alignments and one RPS alignment.
For some reason a guy programmed the BestFit alignment based on RPS. But here the problem is the BestFit alignment creation has to be based on Pre-alignment instead of RPS.
So normal thing to do is manually open each BestFit alignment and change the Heirarchy to Prealignment , which will work 100%.
But here the problem is i have to do for all 100's of alignments.
So I recorded the script for one Alignment change and try to do for all other alignments. but the GOM does not allow this in scripting API
  • Somebody please give any idea to fix this issue ?
  • Does anybody know if the newer version of software shows the same error ?
Im using GOM 2020 version.
image.png.4a9f8df18d857ecaa8c22320308d8441.png image.png.04879c0d0c8b64b72893ba9826ebd5b2.png
you are right. I could drag the alignments without re-opening the window.
Im looking for a easy script solution. I have many projects like this to move alignments , will be much difficult to do one by one.
Also , The script wont work even if we run the same manual recorded steps. I wonder if this has anything to do with version GOM 2020 Python API.
