[Ad...] Posted May 8 Share Posted May 8 Having an issue extracting features from CAD model. CAD model loads correctly. I can extract features from the model, define points on the model, everything is normal. Then when I save the program, I am no longer to do any of that. Can still create characteristics, and create features using probe, but no longer able to extract directly from CAD model. Any thoughts? Link to comment https://qualityforum.zeiss.com/topic/26574-unable-to-extract-features-from-cad-model/ Share on other sites More sharing options...
[Do...] Posted May 8 Share Posted May 8 Interesting. Does Calypso give you an error message or does it just not do anything when clicking the model after saving? Link to comment https://qualityforum.zeiss.com/topic/26574-unable-to-extract-features-from-cad-model/#findComment-150376 Share on other sites More sharing options...
[Ad...] Posted May 8 Author Share Posted May 8 No error message. Calypso is just unresponsive. All other functions work properly. Link to comment https://qualityforum.zeiss.com/topic/26574-unable-to-extract-features-from-cad-model/#findComment-150394 Share on other sites More sharing options...
[Sv...] Posted May 13 Share Posted May 13 Are you logged in as the Master? If not, you might be missing the necessary permissions. Or are you using versioning? Link to comment https://qualityforum.zeiss.com/topic/26574-unable-to-extract-features-from-cad-model/#findComment-150566 Share on other sites More sharing options...
[Za...] Posted May 13 Share Posted May 13 It's likely that you're not logged in as the Master user and therefore do not have the necessary privileges. Here's a couple articles on the topic of user privileges. How to set up - https://portal.zeiss.com/knowledge-base?id=523210 privileges defined - https://portal.zeiss.com/knowledge-base?id=443337 Link to comment https://qualityforum.zeiss.com/topic/26574-unable-to-extract-features-from-cad-model/#findComment-150604 Share on other sites More sharing options...
[Ad...] Posted May 13 Author Share Posted May 13 I am logged in as master user. All functions are accessible, until the first time I save the inspection program. After saving, extraction from CAD model stops working. This includes defining points on the model. All other tools function normally. Link to comment https://qualityforum.zeiss.com/topic/26574-unable-to-extract-features-from-cad-model/#findComment-150618 Share on other sites More sharing options...
[An...] Posted May 15 Share Posted May 15 Maybe you can try healing the model again? Hope that works? Link to comment https://qualityforum.zeiss.com/topic/26574-unable-to-extract-features-from-cad-model/#findComment-150710 Share on other sites More sharing options...
[Jo...] Posted May 18 Share Posted May 18 I had this happen once when the "Work Area" checkbox got checked in the CAD Hierarchy. (There appears to be some sort of system to declare some CAD pieces a fixture and some your model but I could not figure it out and do not recommend touching it) Link to comment https://qualityforum.zeiss.com/topic/26574-unable-to-extract-features-from-cad-model/#findComment-150742 Share on other sites More sharing options...
[Ad...] Posted May 18 Author Share Posted May 18 Unfortunately, healing the model does not work either. Link to comment https://qualityforum.zeiss.com/topic/26574-unable-to-extract-features-from-cad-model/#findComment-150778 Share on other sites More sharing options...
[Je...] Posted May 18 Share Posted May 18 Please sign in to view this username. , I've experienced a similar issue, so I'm curious if yours is the same as I faced. When you open the "Create Features" window and then click on the CAD model, does this allow you to extract and create features while that window is open (by assigning the feature type from the Create Features buttons)? Link to comment https://qualityforum.zeiss.com/topic/26574-unable-to-extract-features-from-cad-model/#findComment-150780 Share on other sites More sharing options...
[Ad...] Posted May 19 Author Share Posted May 19 Please sign in to view this quote. The Create Features button is grayed out in the Create Features window. That seems like it means something... Link to comment https://qualityforum.zeiss.com/topic/26574-unable-to-extract-features-from-cad-model/#findComment-150804 Share on other sites More sharing options...
[Ke...] Posted May 19 Share Posted May 19 What are your CAD load settings set to? I haven't tested it but I wonder if having it set to Model View could be responsible for this. Depending on your Calypso version it is either under "File->CAD Load Settings" or "File->Load Settings" 1 1 Link to comment https://qualityforum.zeiss.com/topic/26574-unable-to-extract-features-from-cad-model/#findComment-150808 Share on other sites More sharing options...
[Ad...] Posted May 19 Author Share Posted May 19 Please sign in to view this quote. 1 Link to comment https://qualityforum.zeiss.com/topic/26574-unable-to-extract-features-from-cad-model/#findComment-150812 Share on other sites More sharing options...
[Ad...] Posted May 19 Author Share Posted May 19 Please sign in to view this quote. Switched to the top selection, and that worked. Thanks! That was a default setting that I was unaware of. Much appreciated. 3 Link to comment https://qualityforum.zeiss.com/topic/26574-unable-to-extract-features-from-cad-model/#findComment-150814 Share on other sites More sharing options...
