Calypso v2022 Unhandled exception WSACONNRESET
Running Calypso v2022, all software information is in the error file attached.
This happens after loading a minimum of two CMM programs with CAD models. Once I try to swap programs from the drop-down Window, it crashes.
This doesn't happen every time, but it sure happens a lot, 6 times this morning and my day started at 7am.
In this example, one program is very small in features, it's a targeting program to ensure the part (Think casting) is correct.
The other program is the machined program (Of the above) and still not a large program at all.
Once this error pops up, the "How do you want to start?" dialog box disappears.
You can't Open files.
You can't Close files.
You can't Save files.
The only option is to Terminate and when prompted to Save any files, select NO.
The error shown is from the offline seat, but this is happening on both of our Contura 2014's as well. Same error.
Any assistance is appreciated.
Unfortunately, I cannot share programs, perhaps with Zeiss engineers and an NDA.
Calypso v2022 Unhandled exception WSACONNRESET.txt
How does this setting get changed?
What could change this setting?
Operators do not have access to these options.
Operators do not have access to the offline seat.
All three Contura 2014's have the same issue.
And sure enough, Nvidia was not set to Autodesk motion builder.
Hello! The solution mentioned here is the most common resolution for that error, but I also wanted to put this link here, as well, in case anyone ever comes across this error and the above does not resolve it. There are a few more things to try listed here: https://portal.zeiss.com/knowledge-base?id=1596796
  • Like! 2
