Attribute for a Plane's Length 2
I know "len" and "length" are valid for the Length 1 property of a plane, but can't seem to find the attribute for Length 2.  (what is the difference between len and length?  Seems odd to have 2 attributes with the same result.
The PCM reference says .length is for curve length. I haven't played around with it but it does return the same value as the formal curve length characteristic.
.length can be used for many things. Most commonly used with pulling the length of things like slots and rectangles.
For Planes; .length pulls the Length 1, and .width pulls the Length 2.
As Charlie stated, len1 will pull Length 1, and len2 will pull Length 2.
  This makes the most sense to me.  Thank you Charlie.
