[Se...] Posted May 13 Share Posted May 13 It happens with every program, big or small. It started all of a sudden. I think it may be related to the fact that I turned on "Results to File" , but that was just for one single program and then I turned it off. I also turned on auto PDF save for some programs, but the lag still occurs for programs that have that turned off. It also happens when only one program is open. Lag is extremely frustrating, especially when you just re-run to pull up a report on results already measured. Thanks (Calypso 2020) Link to comment https://qualityforum.zeiss.com/topic/26616-30-90sec-lag-consistently-just-after-program-completes/ Share on other sites More sharing options...
[Ch...] Posted May 13 Share Posted May 13 When I have a program(s) giving me problems like this I will typically try disabling one result/file output at a time until I find the culprit. Have you already turned everything OFF for testing under "Results to File" and Measurement Tab > Multiple Printout? 1 Link to comment https://qualityforum.zeiss.com/topic/26616-30-90sec-lag-consistently-just-after-program-completes/#findComment-150638 Share on other sites More sharing options...
[Ro...] Posted May 14 Share Posted May 14 Memory, however much you have, double it and then some. Open the tower and pour sticks in. Even the Zeiss provided computers come very under powered. Link to comment https://qualityforum.zeiss.com/topic/26616-30-90sec-lag-consistently-just-after-program-completes/#findComment-150672 Share on other sites More sharing options...
