Drives Shut Off - Z Axis (Contura)
Posted (edited)
We have a Contura G2 that was functioning fine, yesterday. The power went off (overnight) and now the CMM will only move in X & Y Axis. Any attempt to move in the Z direction at any speed results in the drives shutting off. The air is at 4.9 bar; I tried a soft reset of the controller & a hard reset of the controller.
I've never seen this issue with a CMM, so any insight/advice is appreciated.
https://qualityforum.zeiss.com/topic/26652-drives-shut-off-z-axis-contura/
I just happened to have a Zeiss tech here.  He says you have to take the cover off and there are two switches you can turn 90 degrees to release the rollers.  Said to be careful and make sure you don't let it fall.
He also said contura's are sensitive to getting debris on those rollers which could cause what you're seeing.
