[Sh...] Posted June 11, 2021 Share Posted June 11, 2021 Hi everyone, I wanted to get the hang of image correlation. Sadly gom correlate won't let me login. The symbol pops up but disappears immediately. Link to comment Share on other sites More sharing options...
[b5...] Posted June 18, 2021 Share Posted June 18, 2021 Hi, are you on the newest (Hotfix 4) release? We had crashes in the past, that prevented the GOM Software Center from opening. That's what should happen when you click "Login" in GOM Correlate - it would launch/open the GOM Software center. You could try to start it manually, or check if it's installed. But if it disappears like you described, it is likely a crash, therefore I would recommend you to update first. Link to comment Share on other sites More sharing options...
