Counting teeth on a gear without Gear Pro
So we have a small 96 tooth gear (1.063" O.D.) that we have to machine for our customer down to 33 teeth with some other modifications.  Is there anyway to count the number of teeth without GearPro?  We have Curve available as well.
Is there a link or anything to help with creating the WAVINESS characteristic?
Do I just create a circle, or do a 2D/3D curve?
Here is the part in question:
I'm not sure if it works with curves, but it does with a circle. Ive not tried it on a partial circle but had success counting the number of knurls in a circular knob
The problem I have with a circle is that if I don't start on the top of the first tooth, then the probe will jam up against the side of the first tooth and alarm out.
