[Jo...] Posted June 1 Share Posted June 1 I have a spiral 2d curve I am scanning, how do I swap the start/stop points. In other words if I am starting at point 1 and ending at point 1000, how do I swap to change its start and end location? Making point #1 point #1000s coordinates. for additional reference, this is a single 2d line in the CAD. I know the trick about selecting segments in the direction you would like to scan, I need to know how to change directions on a single CAD line.  TIA! Link to comment https://qualityforum.zeiss.com/topic/26752-changing-scanning-direction-on-a-2d-curve/ Share on other sites More sharing options...
[Th...] Posted June 1 Share Posted June 1 The two methods I'm aware of and have used are either to use the arrow button next to the start and end points in a segment strategy, or to select all the points I want to reverse from the feature point list, right-clicking, and choosing reverse points. 1 Link to comment https://qualityforum.zeiss.com/topic/26752-changing-scanning-direction-on-a-2d-curve/#findComment-151416 Share on other sites More sharing options...
[Jo...] Posted June 2 Author Share Posted June 2 Please sign in to view this username. that's perfect! Just what I am looking for 😄  Appreciate the reply! Link to comment https://qualityforum.zeiss.com/topic/26752-changing-scanning-direction-on-a-2d-curve/#findComment-151436 Share on other sites More sharing options...
[Za...] Posted June 30 Share Posted June 30 Here's an article on the topic which goes a little more in depth. https://portal.zeiss.com/knowledge-base?id=3366611 Link to comment https://qualityforum.zeiss.com/topic/26752-changing-scanning-direction-on-a-2d-curve/#findComment-152325 Share on other sites More sharing options...
