New GD&T Extended Protocol Coordinates
Hello, all,
 was so kind to help me with the original formulas for pulling the actual .X/.Y from the Position Characteristic using the new GD&T engine.
GDTPOS=getActual("GDT Position1").extendedProtocol.actualCoord.asArray
GDTVAL=getParameterNamed(GDTPOS).first.asString
GDTX=strElement(1,"@",GDTVAL)
GDTY=strElement(2,"@",GDTVAL)
message("X = "+GDTX+"  Y ="+GDTY)
I haven't used it much, but I have started to, and I'm running into some challenges that while I'm able to overcome it, man does my code get super long and complicated now.
The challenge comes from when the Characteristic is measuring a Cylinder. A Cylinder has two points for evaluation (top and bottom). The StandardProtocol only shows the additional report for the worst case, but the formula above pulls both which leads to a challenge - how do you find the worst case? Well, the only way that I could figure it out is to essentially calculate the Position for both end-points, and then use an if statement to find which one is the worst.
There were also some silly quirks with how the data is presented for the nominal coordinates vs the actual coordinates.
Either way, would someone take a look at this code, and see what I could have done to improve it?
//Nominal Defition Position #32-1
GDTPOS32_1_Nom=getActual("#32-1").extendedProtocol.nominalCoord.asArray
GDTVAL32_1_Nom=getParameterNamed(GDTPOS32_1_Nom).asString
GDTX32_1_Nom=strElement(1," ",GDTVAL32_1_Nom)
GDTX32_1_Nom=mid(GDTX32_1_Nom,3)
GDTX32_1_Nom1=abs(val(GDTX32_1_Nom)/25.4)
GDTY32_1_Nom=strElement(2," ",GDTVAL32_1_Nom)
GDTY32_1_Nom1=abs(val(GDTY32_1_Nom)/25.4)
//Actual Defition Position #32-1
GDTPOS32_1_Act=getActual("#32-1").extendedProtocol.actualCoord.asArray
GDTVAL32_1_Act1=getParameterNamed(GDTPOS32_1_Act).first.asString
GDTVAL32_1_Act2=getParameterNamed(GDTPOS32_1_Act).second.asString
GDTX32_1_Act1=strElement(1,"@",GDTVAL32_1_Act1)
GDTX32_1_Act1_1=abs(val(GDTX32_1_Act1)/25.4)
GDTX32_1_Act2=strElement(1,"@",GDTVAL32_1_Act2)
GDTX32_1_Act2_1=abs(val(GDTX32_1_Act2)/25.4)
GDTY32_1_Act1=strElement(2,"@",GDTVAL32_1_Act1)
GDTY32_1_Act1_1=abs(val(GDTY32_1_Act1)/25.4)
GDTY32_1_Act2=strElement(2,"@",GDTVAL32_1_Act2)
GDTY32_1_Act2_1=abs(val(GDTY32_1_Act2)/25.4)
//Deviation Defition Position #32-1
GDTX32_1_Dev1_1=GDTX32_1_Act1_1 - GDTX32_1_Nom1
GDTX32_1_Dev2_1=GDTX32_1_Act2_1 - GDTX32_1_Nom1
GDTY32_1_Dev1_1=GDTY32_1_Act1_1 - GDTY32_1_Nom1
GDTY32_1_Dev2_1=GDTY32_1_Act2_1 - GDTY32_1_Nom1
//Position Defition Position #32-1
GDTX32_1_Pos1=(2*(sqrt((squared(GDTX32_1_Dev1_1))+(squared(GDTY32_1_Dev1_1)))))
GDTX32_1_Pos2=(2*(sqrt((squared(GDTX32_1_Dev2_1))+(squared(GDTY32_1_Dev2_1)))))
//Comparison Defition Position #32-1
if (GDTX32_1_Pos1 > GDTX32_1_Pos2)
	GDTX32_1=GDTX32_1_Act1_1
	GDTY32_1=GDTY32_1_Act1_1
else
	GDTX32_1=GDTX32_1_Act2_1
	GDTY32_1=GDTY32_1_Act2_1
endif
  • Like! 3
  • Thank you! 1
https://qualityforum.zeiss.com/topic/26770-new-gdt-extended-protocol-coordinates/
Posted (edited)
  Well done. Yeah that has been a quirk/peeve of mine about position of cylinders.
I would think Zeiss 'should' have a PCM attribute for result at each end of the cylinder.
I no longer have access to PCM in my current role, otherwise I would love to dig.
You could probably roll all this into a defineFunction() for ease of use later, etc.
Have we put this in as a request in MyVoice ? If so let me know I'll be happy to vote it up.
Nice work !
