[Mi...] Posted 17 hours ago Share Posted 17 hours ago I took out the actual Part Numbers to avoid leaking any sensitive data. The PCM File runs fine except for the loadCADFile() function. when trying to compute it on its own it returns 0 shown in the attached picture. Any help would be greatly appreciated. Mike // IGVAPCM.txt //variable named 'paramFile' is equal to the actual .para file name // Then 'fileExists' checks if the .para file is in the program's directory then reads(readPCMFile()) it if its there. paramFile = "PARAMETER.para" if fileExists(paramFile) readPCMFile(paramFile) else // If file isnt there, this writes the file to the programs directory addToFile("PARAMETER.para","RH = getRecordHead("u_field1")") // part number header addToFile("PARAMETER.para","ORH = getRecordHead("planid")") // plan/program id header addToFile("PARAMETER.para","DWGREV = getRecordHead("u_field2")") // drawing revision header addToFile("PARAMETER.para","MNAME = getRecordHead("operid")") // machine/operator name addToFile("PARAMETER.para","MAT = getRecordHead("u_field4")") // takes into account the material being used endif // Main selection / confirmation loop starts here. // The repeat...until loop will keep asking until exitLoop becomes true. repeat PART = inquireList("Select the correct Program Number","ZA3657","ZA3658") validSelection = false // reset the flag for this loop iteration fileExists("ZA3657CAD.sat") fileExists("ZA3658CAD.sat") clearCAD() setCoordSysVisible(true) // --- PART-specific cases --- if PART == "ZA3657" loadCADFile("ZA3657CAD.sat") setRecordHead("planid", "ZA3657_PARTNO_002_OP40") setRecordHead("u_field9", "ZA3657_PARTNO_002_OP40") setRunID("ZA3657") // runs the named mini-plan validSelection = true endif if PART == "ZA3658" loadCADFile("ZA3658CAD.sat") setRecordHead("planid", "ZA3658_PARTNO_002_OP40") setRecordHead("u_field9", "ZA3658_PARTNO_002_OP40") setRunID("ZA3658") // runs the named mini-plan validSelection = true endif wait(10) redrawCAD() setFit() // If no valid PART matched (user canceled or selected an unexpected value), show a message if validSelection == false message("No valid selection. Please select a part or check automation headers.") endInspection() else // Refresh header variables so the next steps use what we just set RH = getRecordHead("u_field1") // part number we set above ORH = getRecordHead("planid") // program/plan id we set above DWGREV = getRecordHead("u_field2") // drawing / revision read back MAT = getRecordHead("u_field4") // FIX: ensure the header key is a string // Ask the operator to confirm the displayed metadata before starting exitLoop = confirm("ARE THESE VALUES CORRECT?", cr(),"PART NUMBER: ", RH, cr(),"PROGRAM NUMBER: ", ORH, cr(),"REVISION: ", DWGREV) // confirm returns true if operator clicks Yes/OK endif until exitLoop == true Link to comment Share on other sites More sharing options...
[Je...] Posted 2 hours ago Share Posted 2 hours ago try runPCMFile(paramFile) instead of readPCMFile(paramFile) Link to comment Share on other sites More sharing options...
[Er...] Posted 1 hour ago Share Posted 1 hour ago There is no path to the file. Link to comment Share on other sites More sharing options...
