[Da...] Posted 3 hours ago Share Posted 3 hours ago Is there any way to produce a text line in the middle of our piweb report? Link to comment Share on other sites More sharing options...
[Ma...] Posted 1 hour ago Share Posted 1 hour ago I am using groups to achieve something like this. If you have a newer version of Calypso you can use empty Text element and it will show up on protocol. I think you can also make an formula to hide text if text is something you define - like you'll write in name of text element value "HIDEME" and in PiWeb template it can hide this text ( or remove ) on protocol. Link to comment Share on other sites More sharing options...
[An...] Posted 1 hour ago Share Posted 1 hour ago You also need to enable the uploading of Text Elements. See this Knowledge Base article:ZEISS Portal Link to comment Share on other sites More sharing options...
[Ab...] Posted 1 hour ago Share Posted 1 hour ago (edited) https://portal.zeiss.com/knowledge-base?id=444586 https://portal.zeiss.com/knowledge-base?id=3035751 Edited 1 hour ago Link to comment Share on other sites More sharing options...
