[Ch...] Posted June 24 Share Posted June 24 Hello, I received a measurement plan from another manufacturing site, and when running the plan, I am met with the following error message at the end of the run. The CNC is disabled and the PIWeb report will not print. Where do I access PostSettings in Calypso2025 so I can change this file path? There is no X Drive mapped to this PC. Link to comment Share on other sites More sharing options...
[Lu...] Posted June 24 Share Posted June 24 Hi Christian, It is probably in this menu: Link to comment Share on other sites More sharing options...
[Ch...] Posted June 24 Author Share Posted June 24 Please sign in to view this quote. Thank you for the direction Lucas. It appears that the measurement plan was written with the PCM license, but the machine I am using does not. Is there a simple way to remove all PCM features? Link to comment Share on other sites More sharing options...
[Ri...] Posted June 24 Share Posted June 24 Make a backup, but you can just delete the inspset file inside of the measurement plan folder. You can also manually edit the inspset file and remove everything inside of "#parameters:" If you delete the file, it will also reset things that you might have had setup, mainly things regarding the file output and header parameters. Link to comment Share on other sites More sharing options...
[ni...] Posted June 26 Share Posted June 26 nice, so we can write some PCM code without licence Link to comment Share on other sites More sharing options...
[Ri...] Posted June 26 Share Posted June 26 Yes, but there are still some commands that absolutely require the PCM license (read/runPCMFile being the main one) Link to comment Share on other sites More sharing options...
[Ri...] Posted August 1 Share Posted August 1 Please sign in to view this quote. Edit the "inspset" file, search for the string (Path) in the top image and edit as needed. I would search for "X:\Calypso\QC-Calc Data\History\master Export Files\" Save the file and run the program again. Always have a backup of the file you are editing! Link to comment Share on other sites More sharing options...
[Ch...] Posted 4 hours ago Author Share Posted 4 hours ago Please sign in to view this quote. Thanks Rich, what exactly should I be editing in the inspset file? Should I just be removing the entire line or replacing what's in the ' ' with something else? If for some reason this doesn't work. Is there an easy way to "copy" the features of the program into a new one? Thanks. Link to comment Share on other sites More sharing options...
