[Ke...] Posted yesterday at 05:50 PM Share Posted yesterday at 05:50 PM I have written or edited well over 100 measurement plans in Calypso 2023, and have never run into this issue before. I have 2 measurement plans that I created on my offline system. All features were created off of a solid model, with the MasterProbe being used as the probe. The programs were then loaded onto my Online machine, and the Stylus Systems were changed to ones that I actually run on the machine. Today, when I tried testing these 2 programs, they would complete the first 3 features, which complete my Base Alignment. No additional features would run, however, I can manually execute all of the feature tests, and the characteristics will update, but my Multiple Report will not update. Any suggests on how to correct this issue? Ken Quast 3-D CNC Hutchinson, Mn. Link to comment Share on other sites More sharing options...
[Ca...] Posted yesterday at 07:33 PM Share Posted yesterday at 07:33 PM Ken, are the characteristics all set up correctly? Only features with characteristics will run, so I am wondering if the characteristics are all set up and have the right features pulled in? Link to comment Share on other sites More sharing options...
[Ke...] Posted 23 hours ago Author Share Posted 23 hours ago Caitlin, I can manually execute the Characteristics, and they work fine. But when I try to run the entire Measurement Plan, only the Base Alignment features run, and Characteristics the reference any of the 3 features used in the Base Alignment. Ken Quast 3-D CNC Link to comment Share on other sites More sharing options...
[Ed...] Posted 3 hours ago Share Posted 3 hours ago I've seen this behavior when I left "Current Selection" active. Link to comment Share on other sites More sharing options...
[Ke...] Posted 56 minutes ago Author Share Posted 56 minutes ago Thank you Caitlin and Edgar for your responses. I checked for the issues that you both mentioned, however, neither seems to be the case. What I did find is that when I reassigned the stylus systems at my online machine after programming, I neglected to change the Measurement Plan default to an active stylus system. Once I corrected this, the Measurement Plan worked as expected. Ken Quast 3-D CNC Link to comment Share on other sites More sharing options...
